programmatically change position of front panel splitters
Is there a way that one can programmatically move the position a front panel splitter?thanks
(6,048 Views)
Accepted by topic author alpony01
Yup, you can right click the slider and select Create Reference.  Then wire that reference to a property node and select the Splitter Position property.
(6,040 Views)
thanks..worked perfectly
(6,021 Views)
I probably missed something, but when I do so, I only get the error code 1029 (Read-Only property). Plus no matter the position of the splitter, when I use it in "read" mode, it always gives "Left=0, Top=26"...
I am just using a test VI: empty with just a splitter, the indicator or control for the position and the property.
Do I have to activate something?
My bad, I didn"t cease the different between Splitter, Position (cluster) and Splitter, Splitter Position (Integer).
(5,596 Views)
