multi language interface
Hallo guys:I confront a problem recently, my boss wonder a program with multi-language, just different language interface, and the same background block diagram code, so is there any advices or ideas?I considered a method, package the main code, and develop several sub-Vis with different language interfaces, they all call this integrated code.Any better solutions? Thanks for your concern!
(4,814 Views)
Accepted by coolbear
Here's an article on NI Zone entitled Localizing Your LabVIEW Application to Different Languages.  Take a look, also, in LabVIEW's help for "Localizing VIs".
Jim
Jim
(4,811 Views)
LabVIEW supports single and double byte characters, but it does not support bidirectional scripts (such as Arabic or Hebrew). If you want to display text in multi-byte character sets (such as Japanese, Chinese, or Korean) in LabVIEW, you only need an operating system of the appropriate language or an MBCS-enabled operating system with an Input Method Editor (IME) for the corresponding language. Also, there are several commercially available language kits that you can add on to the operating system. Search for localize labview on the website and the forums. Here are some articles that I could find:
Localize LabVIEW Applications in Multiple Languages [broken link removed]
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(4,810 Views)
thanks guys.
(4,796 Views)
