multi plotting limit?
Hi there.
I need to plot a force x position curve for a automated process and then some rectangles on it, that will be the regions of the graph that will be analyses ( if the graph passes through every rectangle I have, its fine ), but I am having some problem when plotting more than 4 of these rectangles ( picture attached ). Is there any limit of xy plots that can be done simultaneously on a XY graph? Does anyone knows other way to plot that does not cause this? I am generating every array used to form each of the rectangles and then merging everything and plotting ( there must be a easier way)
Fernando H. Moreno
(3,325 Views)
There is a practical limit, but I can assure you that 4 is WAY below that. It seems that the way you're building the graph is excessively complex. With an XY graph you provide an array for multiple plots, and each plot is a cluster of 2 arrays: an array of X value and an array of Y values. Thus, to plot your line and one rectangle you'd do something like this:
(3,314 Views)
Actually Im doing way more than 4 plots, but I agree the way Im doing is very complex! will try your suggestion here!
(3,293 Views)
(3,292 Views)
Accepted by Fhmoreno
If you want to keep using xy graphs, consider switching to complex arrays to keep the data structures simpler. You can also graph all elements having the same color as a single plot, simply making gaps using a point cointaining NaN in between islands.
If you really need to graph all these squares, I recommend to switch to a picture indicator instead.
(3,286 Views)
