multi word serial reception
Hi all,
I receive from my equipment data ,on serial communication ,with words separate by 'return' .
I use a master/slave loop to avoid missing message .
My problem is that the number of word is not the same on each reception (i don't know the number i will receive):
ie :
first reception : 23455\r
second : 35435\r56755\r
third : 354353\r56765756567\r456464\r
fourth : 7567\r
But I need to answer to each word ,but as the text (Data received) enter in my buffer are not same lengh my answer is not correct.
As anyone have a solution ?
regards
Rock31
(2,397 Views)
Accepted by topic author rock_31
Just set the Termination character to \r and enable end on termination character using Serial Initialize.vi.  Read 1024 characters.
Then Read.vi will return whenever it sees a \r coming in (or 1024 characters Or timeout but you'll see the \r first Smiley Wink)
(2,395 Views)
Thanks a lot for your help Jeff !!
It's works now.
Smiley Very Happy
Rock31
(2,373 Views)
