multiple UDP receivers in one vi?
Accepted by Steffen01
there you go. And at least if the sender has wait xxxx ms then receiver loops every xxxxx ms. Neat.
I attached sender and receiver vis for the future reader.
Gard, If you ok with the attached files, I will mark it as solution.
Message 11 of 15
(1,388 Views)
Hi Steffen,
- I prefer "preallocate" over "shared" clone in the reentrancy settings…
- Your CRC16 subVI already provides the CRC as string: you don't need to convert (serialize) the U16 CRC result again to string…
Message 12 of 15
(1,382 Views)
help said shared is the safest option.
Message 13 of 15
(1,377 Views)
"pre-allocate" makes clones for each instance, guaranteeing that one instance won't influence another.
Bill
CLD
(Mid-Level minion.)
Message 14 of 15
(1,369 Views)
http://zone.ni.com/reference/en-XX/help/371361M-01/lvconcepts/reentrancy/
ok, I go for pre-allocated. Don't care about memory space, this PC sole purpose is to run the Labview application.
Message 15 of 15
(1,359 Views)
