multiple cDAQ Chassis
I will be using multiple cDAQ chassis across a network. Is it better to create a separate DAQmx task for each chassis or combine into 1 large task?
(3,616 Views)
Accepted by NNS-CAO
I have not tested it with multiple cDAQ chassis, but there are many PCI/PXI cards that will not even let you have a task go across multiple cards.
My opinion, I would use seperate tasks for each chassis.  Makes the code a little more modular.
(3,599 Views)
Thanks. That was what I thought.
(3,593 Views)
