multiple cases
Hi There,
In my program i am getting output in gram unit. I want that if value to be in readable way between 1-1000. So if value is more or less then that, i want to transfer it into either, microgram, milligram, gram and kilogram to display value and also able to display string for unit accordingly.
Is there a way to use case structure to solve this problem
BTW i am using labview 8.2.
Yogesh
Message 1 of 11
(5,523 Views)
How about this (attached).
You can set a case structure to accept a number as the selector.
Then you can set a range for each case.
For example '0..1000' would be 0 to 1000.
You can then multiply/divide by whatever you need to in order to get the correct units.
Then append the correct unit as a string.
Message Edited by Cory K on 09-15-2009 02:18 PM
Cory K
Message 2 of 11
(5,513 Views)
I'm not sure if it's available in 8.2, but try to set your display indicator to SI NOTATION (under DISPLAY format).
It will automatically append "m", "u", or "k" (or others) as necessary.
Steve Bird
Culverson.com
LinkedIn
Message 3 of 11
(5,503 Views)
Accepted by topic author Yogesh9ic
Hi Yogesh,
when switching on "unit display" for indicators LabView will do the part of (SI-)unit scaling for you...
Message 4 of 11
(5,494 Views)
I think I'm going to stop writing code from scratch.
Every time I do, LabVIEW already has a function/option for it that I dont know about or didnt see before. Smiley Very Happy
Cory K
Message 5 of 11
(5,462 Views)
I hear you cory lol you do all that work and BAM!! already done with labview
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 6 of 11
(5,459 Views)
Yeah lol, I wrote a ton of programming for DAQ, then found the express DAQ assistant Smiley Tongue
Tyler C. | Certified LabVIEW Associate Developer
Message 7 of 11
(5,447 Views)
in all honesty I never use the DAQ Assistant I tend to right my own software for that
Message Edited by Harold Timmis on 09-15-2009 05:57 PM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 8 of 11
(5,442 Views)
I tend to right my own software for that.
Do you write your own spell checkers, too?
Smiley Wink
Steve Bird
Culverson.com
LinkedIn
Message 9 of 11
(5,435 Views)
that would be me hitting the forum spell checker and me not looking back at what was written lol:)
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 10 of 11
(5,433 Views)
