04-16-2009 10:08 PM
04-20-2009 10:38 AM
Hi Turbine,
The Frequency Measurement Task uses a counter to measure the number of ticks between periods of a signal. Because of this there is no acquisition timing Delta_X as there is with typical analog input tasks. So you can disregard the Delta_X = 1.0000 portion in the header of your LVM file for the frequency measurement. This 1.0000 value just seems to be default value entered for frequency measurements in order to maintain a consistent header.
