multiple vi same cDAQ
After programming for a year or so, I never ran into this proble before:
How to I run multiples vi (I need 2) using the same cDAQ 9172   (I have two TC modules 9213--I believe); I have the usual problem that only one works at the time.
May you give me just a simple...
(3,108 Views)
The simple answer is that you can only have a single task running. You would need a single VI that has a task with both channels in it.
(3,101 Views)
I already found my answer; I am using a common subVI that gather all the data for the two differewnt Main VI s.
(3,092 Views)
