multiplot with labview.
HI experts, the following vi should produce a multiplot but I dont know how to plot it. I could use the x-y graph example but I want my number of plots to be able to vary. does anyone have any idea on where to begin?. Roshan.
Message 1 of 20
(9,454 Views)
Hello people. I could use the following vi to do the multiplot but I was wondering if there was a way to do it in real time? lets say as a new plot is built, it is updated into the graph. thanks. Roshan.
Message 2 of 20
(9,447 Views)
You need to add a "shift register" to your loop, and a build array node, to be able to stack the data of the different plots. See the modified vi.
CC
Chilly Charly    (aka CC)
Message 3 of 20
(9,440 Views)
HI there Charlie, Unfortunately, I dont have labview 7.1 and I could not open it up with labviw 7.0. COuld you kindly convert it to 7.0 or just send the wiring diagram as a jpeg. Thanks. ROshan.
Message 4 of 20
(9,431 Views)
Here it is !..
CC
Message 5 of 20
(9,428 Views)
Excellent, Mr. chilly charly. You were incredible! that was such a nice quick fix for a problem i was trying to solve in a very complecated way. Best regards,
Roshan.
Message 6 of 20
(9,401 Views)
Hi..i'm using labview 8.0 and right now i'm facing a problem with opening the lvm file. when i try to open the file, the message 'the file test.lvm is not a valid labview file' appeared. can anyone help me?...thanx...
Message Edited by HANI on 02-06-2008 12:13 AM
Message 7 of 20
(9,086 Views)
Hmm, sounds like your *.lvm file has become corrupt.
How did you create this file??
Or, were u able to read it prior and now, are you unable read it??
Message 8 of 20
(9,082 Views)
I've used this lvm file for the first time, also still new in labview. i create this file via 'write to measurement file' icon. or is there any possibility that my labview library was lack of something?
Message 9 of 20
(9,073 Views)
What data ( format of data) are you writing into the lvm file?
Message 10 of 20
(9,057 Views)
