02-07-2008 12:30 PM
02-10-2008 05:08 AM - edited 02-10-2008 05:10 AM
02-11-2008 11:08 AM
03-18-2008 03:22 AM
03-18-2008 04:18 PM - edited 03-18-2008 04:18 PM
07-23-2008 06:11 AM
07-24-2008 06:01 PM
Hi terwelu,
Make sure you follow what the Error Opening LVM Files in DIAdem KnowledgeBase discusses.
The cannot load lvm file into diadem forum post discusses of the same problem.
- Did you attempt to open the same LVM file created in PC1 in PC2?
- Can you post a copy of the LVM file causing the problem?
07-28-2008 07:54 AM
07-28-2008 11:55 AM
Hi terwelu,
I was able to download, and note that in your LVM files there are no headers as described in the cannot load lvm file into diadem forum post. After adding the necessary headers, I was able to successfully open both files in DIAdem 10.2.
I reformated the files using a simple VI. In the VI I have a Read From Measurement File.vi to read your raw LVM file, followed by a Write to Measurement File.vi, with "One header per segment" option enabled; this option adds the necessary header information for DIAdem to successfully interpret the file.
Attached is the simple VI to add the necessary header, and the now readable LVM files.
Note terwelu, that an Add-In is available to read TDM files in Excel.
You may download the free add-in at:
TDM Excel Add-In for Microsoft Excel Download
Hope this helps terwelu. . .
07-29-2008 04:35 AM
