my chip provides 4-pins to select slave.now how can i simulate this using VI.Is there any example code that can be re-used .
my chip provides 4-pins to select slave.now how can i simulate this using Labview.
Is there any example code that can be re-used,it should also be supporting serial communication
(2,136 Views)
Hi karthikk,
- Didn't you asked that question atleast two times before?
- Didn't we already told you not to create new threads with the same question?
See here and here!
Maybe you should provide more information (in your original thread!) instead of asking the same over and over again?
Maybe you should also answer when someone trying to help asks back on you...
(2,134 Views)
