‎06-14-2013 12:44 AM
Dear Sirs,
I have a project to measure ac Electrical parameters such as current, voltage, power factor etc. through data aquisitioin with labview. Can I do that ?? If yes then kindly help me with some opinions and ideas. I shall be highly thankful to you.
Muhammad Hanan Azam.
Student of University of Engineering and Technolgy, Lahore, Pakistan.
Solved! Go to Solution.
‎06-14-2013 01:00 AM
Yes it is possible. This can be acheived through serial communication. Read about serial communication like VISA, VISA configure, VISA wite, VISA read etc.
Read about the serial communication of device with you are going to communicate i.e. some communication document etc.
‎06-14-2013 02:29 AM
Do I need mydaq device for that ?? If no then can it be done with mydaq? or which will be better?
‎06-14-2013 02:36 AM
What is mydaq?
‎06-14-2013 02:59 AM
‎06-14-2013 03:10 AM
Depends on your requirement
‎06-14-2013 03:36 AM
You want to measure the ac voltage and current using labview from which device ?
‎06-14-2013 05:48 AM
I do not know which device will serve my purpose. Thats why I want to know that what device or method I should choose.
‎06-14-2013 05:54 AM
I went through the link you provided and I think that is best for you becasue it is made for students with lots of advantages.
‎06-14-2013 06:24 AM
But I need it confirm that my task can be done by that device because it is very costly and I m not a professionalist.
