myDAQ, connect sensors with multiplexer in labview
I am quite new to labview so hope someone can help. What  I am doing is to use NImyDAQ to connect 8 different sensors and show the output on labview. Since the myDAQ does not have enough input for 8 sensors, so I am using two 8 bits multiplexers to solve it.
Here is the question. How do the circuit draw in the labview which will make it works? I want to make an drop down button to select which sensor is connected and shown, therefore I need to output boolean value (0,1) to the digital input/output? I have try using case structure but seems difficult for me. Is there any example similar to what I am doing?
(3,698 Views)
It's actually very simple. Your drop down needs to output the numeric values of 0-7 and the numeric (a U8) can be wired directly to a DAQmx Write that is correctly configured. Skip the DAQ Assistant of you were considering it.
(3,667 Views)
What you mean by skiping the DAQ Assistant? Can you make a drag and drop diagram for an example? I have no idea how the drop down menu giving out numerical value then goes into the Digital input in NImyDAQ.
(3,651 Views)
For examples, just use Help> Find Examples. Then go to Hardware Input and Output.
Look at the options you have for the different drop downs.
Most of this is covered in the free tutorials.
(3,641 Views)
