myRIO 1950 Write Data To File Memory Leak
@Relec wrote:
Fun Times.
I just did the exact same thing you did.  Using an sbRIO 9637.  So much time wasted because I assumed it was something I had coded that was causing the problem.
Unfortunately I don't have the option of upgrading to LabVIEW 2019.  Using 2018 SP1 at the moment.
It appears that I can run for about 20 hours before I start running out of memory.  I might try to put an auto-reboot in the code.  Which isn't much of a solution if you expect your system to collect data and run continuously for years.
Relec
I also have a project that crashes due to know memory after about a day of running on my myRIO. The code is also deployed on a sbRIO in the field and it doesn't experience the issue. The only difference is that the code in the field always has the connection to a message broker established and on the myRIO, which I use for testing purposes, doesn't have the message broker connection because I don't leave that running 24/7. The application will automatically try to re-establish the connection. That is the only difference in the execution path between the deployed system and my test bed. Since the deployed system isn't exhibiting this issue I haven't fully investigated the cause. I have tested out the messaging libraries for issues but this was done on a PC. This just shows that it is not a fundamental issue with the library itself.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 11
(302 Views)
