myRIO Servo Motor demo control issues
Hi all,
I'm using the myRIO to control my Corona CS-239MG Analogue servo motor however I am running into a major issue: It won't actually stay in one position, but swings back and forth CW and CCW. Here is a video I have uploaded to YouTube:
https://youtu.be/z3Eluin3sWo
This is running the standard NI Project Essentials guide demo software that I downloaded from NI. Any assistance will be helpful, I've never worked with either LabVIEW or the myRIO.
Thanks so much!
(3,585 Views)
Hi Rhettyj92,
Because this is more of a motion control or myRIO issue, you may find that you have better luck posting in one of the more specific forums- I would start with the motion control forums, since it sounds like that's likely where the issue lies. Make sure you include information about whether you're working with NI-Motion or SoftMotion, as well as what kind of motor drive you're using, so that the folks there have a better understanding of your system.
You should also consider either going to www.ni.com/support or calling into our support line (866-275-6964) and opening a Service Request, so that you can work with one of our engineers to track down the cause of the problem.
Kathryn K.
Technical Support Engineer
http://ni.com/support
(3,556 Views)
