FTP file upload file to FTP server
I am able to put file on FTP server when i am using published vi on my computer .But when i am trying to put file into FTP server  from other PC connected in same network .Its give error
Message 1 of 22
(15,971 Views)
@piZviZ wrote:
Its give error
What's the error?
Message 2 of 22
(15,960 Views)
Look at this attachment
Message 3 of 22
(15,949 Views)
What happens if you define a real remote path instead of just a file name? See the help.
Message 4 of 22
(15,911 Views)
FTP Transaction:
550 Filename invalid
Error -15550
Message 5 of 22
(15,877 Views)
Accepted by topic author piZviZ
Hey..I am awaiting for your replay
Message 6 of 22
(15,835 Views)
You don't really give sufficient information to troubleshoot this further.
  • Is the file name properly formed? What is now the exact text in the "remote path" string diagram constant.
  • Does the target folder exist?
  • Do you have write permission?
  • Does it work if you use a regular ftp client to access the remote computer and upload the file to the same target location ?
Message 7 of 22
(15,816 Views)
remote path =  vicky.docx
I am publishing this vi using web server.So client can give path of file(using browser) that they want to put into server..
When i am trying to put file into server locally .Means PC where server running from that  PC  browser i am writing file to server it work well.
Message 8 of 22
(15,809 Views)
Filezilla shows sucessfully file transmitted...
Message 9 of 22
(15,807 Views)
So you have not tried my suggestion form post #4?
Message 10 of 22
(15,802 Views)
