FTP file upload file to FTP server
i tried and its give... error
FTP Transaction:
550 Filename invalid
Error -15550
Message 11 of 22
(5,325 Views)
i tried it gives error
FTP Transaction:
Error -15550
Message 12 of 22
(5,324 Views)
... tried what? You said you are still using the string "vicky.docx" as remote path.
... and why would you mark your pointless message #6 as solution to this thread???
Message 13 of 22
(5,310 Views)
(1)    First i tried using
              remote path =  vicky.docx
(2 )..Then according to your sugesstion
i changed
Remote path= D:\vicky.docx
Aat that time i got
  FTP Transaction:
Also this syntex is not work==>D:/vicky.docx
(3).Then i came back to old remote path and at that time u asked me about path ..That is reason why i mentioned                remote path =  vicky.docx.
(4).I was replaying from  mobile and due to that may be possible i clicked on solution button..
Message 14 of 22
(5,299 Views)
What is the OS of the ftp server?
Message 15 of 22
(5,288 Views)
window8.1
Message 16 of 22
(5,277 Views)
Windows 8.1,
64 bit Operating system
Awaiting For your replay
Message 17 of 22
(5,251 Views)
Well, I don't have a windoes ftp server so I cannot test. You said it works if you use a ftp client. Can you upload the file via the filezilla ftp client again and then attach the message log of the ftp session showing the syntax that was used for the succesful transfer. (more info)
Message 18 of 22
(5,237 Views)
I did not tell you that FTP client can upload.I tried from local machine browser and it work locally.But from network machine it does not work.
Next,I tried using Ftp client but it cant establish conection with server shows Failed to connect..
Is there any alternative of FTP in labview for transferring file??
Message 19 of 22
(5,185 Views)
You said that you had success with filezilla. You need to be more specific thenthen if this is not what you meant.
So it seems ftp is blocked (firewall, etc.). Maybe you should talk to your network admin.
Message 20 of 22
(5,169 Views)
