myRIO controls in the functions pallet
hi all,
i fired up my myRIO today after being filled with confidence on the real time 1 course and looking at a bunch of examples.
whats scuppered me is i cant find any of the vi's in the functions pallet, i thought they would be in the same place like the DAQmx stuff but no bannana!
i just want to write a few simple VI's to play at some anaglog/didtial io and bosh im stuck!
please point to the pallet and save my sanity!
(i find it quite funny really as i suspect they are right there infront of me)
Message 1 of 16
(6,206 Views)
I don't have a myRIO so my answer may not be correct.  But I would first start in the Help >> Example Finder and search for myRIO and see what there is for basica connection and I/O.  Then I would go to the functionals palette, and click search then search for myRIO which will hopefully show you where in the palette is the myRIO functions.
Message 2 of 16
(6,191 Views)
good call, i tried that.
using an example from the project essentials guide i can find the names of what im searching for but then when i go to a blank VI to start writing my own i i cannot find them in the palet even if i search the name.
it looks pretty uch like a DAQmx VI and from the couple ive seen the logic looks a bit like daqmx too.
if i use context help and clik the detailed help link it shows myRIO in the help its the next one down from myDAQ. it explains the VI but then when i click the "show on pallet" link i get an error saying
object not found possible reasons include
1. the object might exist in a different pallet view
2. the object might not be supported  on a target in the project explorer window
3. ....... something to do with expired licence
4. bject uses functionality not supported on the operating system
Message 3 of 16
(6,158 Views)
Hi Dombanks,
Did you create a new project?
Did you include the myRIO as target in the new project?
Did you create the fresh VI for that target?
Why don't you show a picture of the block diagram when you talk about some "unknown objects" without naming them correctly?
Message 4 of 16
(6,155 Views)
LabVIEW has developed a palette with express duties to begin work on this device, there are few examples of Myrio in the form of examples, but I'll leave a link to the academic community of national instruments, you can search by category and you will find examples developped, Greetings
https://decibel.ni.com/content/community/academic/products_and_projects?view=documents#/?tagSet=1869
Message 5 of 16
(6,067 Views)
Dear all;
i have a labview 2013 software installed in mypc ,but it have no myRIO control and function palette.even when i am try to download 2013myRIO.exe i have encountered an error.what shall guys?
thank you
Message 6 of 16
(5,919 Views)
Hi samuelaa,
AFAIK you need to install the LabVIEW RT (Realtime) module additionally to your "standard" LabVIEW environment…
Message 7 of 16
(5,911 Views)
@samuelaa wrote:
Dear all;
thank you
First the really obvious question: Did you install the myRIO version of LabVIEW that came with your myRIO?
Message 8 of 16
(5,901 Views)
i have no myRIO hardware in the lab but i have downloding the add on toolkits and intalled them like pid and fuzzy logic ,labview real time ,labview mathscript toolkits thank you. samuel
Message 9 of 16
(5,882 Views)
Dear Gerdw; yes,i have installed labview RT module
Message 10 of 16
(5,880 Views)
