myRIO controls in the functions pallet
@samuelaa wrote:
i have no myRIO hardware in the lab but i have downloding the add on toolkits and intalled them like pid and fuzzy logic ,labview real time ,labview mathscript toolkits thank you. samuel
But did you install the myRIO software?
LabVIEW 2013 for myRIO Module
Message 11 of 16
(1,135 Views)
i didn't have a myRIO hardware but when i  download the 2013 myRIO.exe and try to install,it says no software to be installed!
Message 12 of 16
(1,131 Views)
When you start your LabVIEW 2013, under the Tools menu, do you have a Choose Environment option at the top?
That option makes it posible to switch between "normal" LabVIEW and myRIO LabVIEW version.
Message 13 of 16
(1,119 Views)
I think that just changes some of the looks.  I just tried it, but the myRIO VIs were still in the palette.
Something that just donged on me though.  The myRIO palette is only available if you are in a myRIO target.  If you don't have a project with a myRIO target, you can't access that palette.
Message 14 of 16
(1,114 Views)
yes there is a choose enviroment in the tools menu,but still when i make in the labview for myRIO enviroment the myRIO palett doesn't exist.is myRIO hardware must be plugged to access this palette.
thank you
Message 15 of 16
(1,099 Views)
Hi , i'm YUSUF
i have the same probleme
after installing LabVIEW 2013 for myRIO Module, i don't found the function's palette of myRio
i created a project like you said but i have the same probleme
please tell me the stapes to do a project with myRio (software and hardware requirements)
Message 16 of 16
(947 Views)
