‎06-21-2014 09:49 AM
@samuelaa wrote:
i have no myRIO hardware in the lab but i have downloding the add on toolkits and intalled them like pid and fuzzy logic ,labview real time ,labview mathscript toolkits thank you. samuel
But did you install the myRIO software?
‎06-21-2014 10:02 AM
i didn't have a myRIO hardware but when i download the 2013 myRIO.exe and try to install,it says no software to be installed!
‎06-22-2014 03:32 PM
When you start your LabVIEW 2013, under the Tools menu, do you have a Choose Environment option at the top?
That option makes it posible to switch between "normal" LabVIEW and myRIO LabVIEW version.
‎06-22-2014 04:18 PM
I think that just changes some of the looks. I just tried it, but the myRIO VIs were still in the palette.
Something that just donged on me though. The myRIO palette is only available if you are in a myRIO target. If you don't have a project with a myRIO target, you can't access that palette.
‎06-23-2014 01:04 AM
yes there is a choose enviroment in the tools menu,but still when i make in the labview for myRIO enviroment the myRIO palett doesn't exist.is myRIO hardware must be plugged to access this palette.
thank you
‎01-21-2016 02:24 PM
Hi GerdW , i'm YUSUF
i have the same probleme
after installing LabVIEW 2013 for myRIO Module, i don't found the function's palette of myRio
i created a project like you said but i have the same probleme
please tell me the stapes to do a project with myRio (software and hardware requirements)
