myRIO not appearing in "Remote Systems" in MAX
I was trying to configure the myRIO to Wi-Fi when I found out that the device was not recognized in the remote systems part of MAX. The device works fine when using real-time and FPGA, only this part is not working. When I try to "troubleshooting remote system discovery" the device is also not found when I’m arriving at the "searching for remote system step and an error will pup up:
Error 1 occurred at Release Queue in Discovery Wizard.lvlibp:Find Targets - Get Target Details.vi->Discovery Wizard.lvlibp:Find Targets.vi->Wizard Framework.lvclass:Run Page.vi->Wizard Framework.lvclass : Page Engine.vi->Discovery Wizard.vi
Could someone give me some advise?
Kind regards
Stefan Ketelaars
(4,809 Views)
Accepted by stefan_keet@live.nl
  1. Have you ever connected to this myRIO?
  2. Are you trying to connect via USB or WiFi?
  3. If WiFi, is your PC's WiFi "on"?
(4,799 Views)
Thanks for the response,
It was a very basic mistake the wifi from my laptop was turned off.
thanks for the help!
Kind regards
Stefan
(4,757 Views)
