myRIO wifi problem
I am working with GPS program.When i run the VI using a USB cable I am  able to get the desired output.But when I am using WiFi connection I am getting the following error.I am not using myRIO's wifi connection.Instead I am working with the department's wifi connection.Please4 help me to resolve this problem
(2,772 Views)
Is the myRIO connected to the department network?
(2,759 Views)
Accepted by iniya
Finally,we got the output using myRIO WiFi.I had connected the LAN connection to my system.After I  removed the LAN connection I was able to dump my code successfully using myRIO WiFI
(2,709 Views)
