myRio-1900 Green power project
Currently working on a Green power project using RIO and client computers, tablet, webserver and phone.
Looking for any tips on FPGA coding(touch screen, i2c, SPI, Wifi, 4G/iot).
kls
Message 1 of 16
(4,645 Views)
Hello kls,
Giving "any tips on FPGA coding" is at random. Do you have a topic on mind?
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
Message 2 of 16
(4,590 Views)
Adding touch screen to myRio, what screen is best for myrio and any codes to get started.
Be able to read data from SPI Devices like the ADS1256, PmodAD5.
kls
Message 3 of 16
(4,579 Views)
Accepted by Kimlorentz
Hello kls,
Regarding Touch Screens and myRIOs, there are lots of different approaches possible. Had you seen this thread already: myRIO LCD Touch Screen Support? So your first question should be: What kind of touch panel do you want to use? What's your goal for it?
Regarding SPI, the approach depends on your ultimate goal as well. There are different drivers available, e.g. SPI and I2C Driver API - National Instruments. After installing this, there is an SPI example available in NI Example Finder for LabVIEW. There is also an example project here.
CLADMSD
Message 4 of 16
(4,572 Views)
please help!!!!!!!
What happens is that I want to run the example of quicstart to connect to IBM but I get a code error 7601 and can not be done everything and I do not know how to solve it please help me
Message 5 of 16
(4,475 Views)
please help!!!!!!!
Message 6 of 16
(4,475 Views)
Good morning
Can you please help me with a tutorial to connect the
myRIO 1900 card with thingwox Industrial Connectivity
Configuration 8. They would help me a lot to advance in my project. My email: alexandra67chiluisa@gmail.com Thank you.
Message 7 of 16
(4,467 Views)
I am sorry but I don't know what 7601 error code is.
kls
Message 8 of 16
(4,451 Views)
@lili95 wrote:
please help!!!!!!!
What do you mean by "IBM"?    The company? IBM
Message 9 of 16
(4,443 Views)
Alexa, what exactly is "thingwox Industrial Connectivity Configuration 8" and what exactly do you need to know? As far as I understand thingworx Industrial Connectivity is a quite huge client/server framework which supports like a dozen different interfaces. As LabVIEW / myRIO is an open platform itself, you can use a hand full of different approaches to connect these two. Which approach do you want to use?
CLADMSD
Message 10 of 16
(4,387 Views)
