myrio gps
http://www.youtube.com/watch?v=SebcpkbYBd4   I am currently using the adafruit GPS sensor and connecting to the myrio.
I was following along with the example above, due to it being a patch antenna and I keep getting errors, I have attached my Vi, below.  I just want to continuous take measurement's from the GPS sensor.
Does anyonne have any suggestions?
Thank you,
Billy
(4,082 Views)
Hi Billy,
Can you provide more details about the errors occurred in your code. Attaching some screenshots of the errors would be great.
Also, I suspect that your VISA resource is not closed properly based on the codes that you've attached.
Ee Lim
See that button on the left side of this post...
If you feel my post is helpful, all you need is just (at most) 2 seconds to click that button, to show your appreciation. Thank you~~
(4,059 Views)
It is a Visa error!
I've included a snapshot of the error in this message.
(4,035 Views)
Hi Billy,
Can you check whether you have the NI-Serial and NI-VISA software installed in the myRIO?
And also, check if whether selecting COM1 works for your code.
I believe this error is related to the link below.
http://digital.ni.com/public.nsf/allkb/570B021DEBA08213862579990074F9D1
Ee Lim
(4,020 Views)
Yeah I don't have serial mysteriosly.  Sorry i've been looking into this.  I went to Add/remove software on NI Max and I was expecting to find it, any suggestions?
(3,987 Views)
Greetings cwatts26
Is NI Serial listed in “Available add-ons” on the NI Compact RIO Software wizard from NI MAX?
If it is not, can you confirm that NI Serial is listed under software on the “My System” tab in NI MAX. Have a nice day.
Warm Regards,
Luis J.
(3,933 Views)
