nD 3 equation nonlinear solution to find 3 unknown variables
Hello, I tried to use nD Nonlinear System Single Solution to solve
X+3y+2z = -1
2X+4y+3z = 2
-x+2y+4z = 5
I know the answer to x,y, and z but I wanted Labview to figure it out. Here's my attached vi in LV 2009 and it only tells me that those 3 equations are soluable and reached 3 zeros.. What I really wanted is to find real answer of x,y and z.
Thanks.
(3,914 Views)
Oops, I forgot to save those data as default. Here's the vi with default values.
(3,911 Views)
Accepted by topic author William_Wood
you are solving f(x)=0 so you need to move the constants to the LHS of your equations:
 x+3y+2z+1=0
2x+4y+3z-2=0
-x+2y+4z-5=0
[0,0,0] works for a starting point and you find the solution is (3,-4,4)
(3,900 Views)
Awesome! That solved it. How about VI instance version? I tried to strict typed VI and it works but I saw that X and F(X) is number not string and F(X) is considered indicator instead of control or constant that confuses me.
(3,889 Views)
The VI that you supply has a simple job, take in n values (ie. x,y,z values) and return the n function values in F(X).  The variant is there in case you want to pass additional values, such as the coefficients for a more general case.  For your case here is a simple example.
(3,877 Views)
Ah! It solves it again. Many thanks Darin. 🙂 I didn't know that I have to actually fill in formula equations in VI template to do the job.. I learned something new today. That's all I need. Thanks again.
(3,873 Views)
