name in front panel
Well guys I made a program here in LabVIEW...
and than I saved it with the name "Show 4V4I 480V"
but when I saw, in the front panel it was appearing "Show 6V3I Vbat 2008 [Show 4V4I 480V]"
I took an old program here that "show 6v3i vbat 2008" and make some changes and than adapt to what I want
now, How can I change this name in front panel?
I never see something like that =/
Message 1 of 9
(4,262 Views)
Please attach a screenshot of the front panel so we could know what exactly is happening.
Message 2 of 9
(4,260 Views)
here, the file name:
and here is the name that is appearing in front panel:
Now I want to know, how can I change the name is appearing in front panel!
Message 3 of 9
(4,247 Views)
Accepted by EduU
Norbert
Expert: Geometry
Message 4 of 9
(4,244 Views)
I am assuming you want to change the name in the title bar.  IF you want a static name you can change the name in the properties, under Window Appearance.  Dyanmically, you can use a VI Property node to make it whatever you like.
Message Edited by PJS on 11-18-2009 07:39 AM
Paul
Message 5 of 9
(4,243 Views)
ok guys, you answered my question!
Now I have one more, and I can remove the name in [] ?
like I want the title in front panel
appears only "show 4v4i"
Can I make that?
or the name of vi will always appear?
Message 6 of 9
(4,235 Views)
Name always appear when the VI is not running.
Paul
Message 7 of 9
(4,230 Views)
oh I see now! thanks PJS and Nobert B.
you two answer my question, but Nobert did it first
so i will give him the solution and a kudos to you PJS, ok?
was my fault!
Message Edited by EduU on 11-18-2009 07:07 AM
Message 8 of 9
(4,225 Views)
No worries.  Glad to help, no matter who gets credit! :manwink:
Paul
Message 9 of 9
(4,219 Views)
