narda EHP-50D device control
I need to integrate control of Narda EHP-50D device into my applicatino.
There is no support for this device for Labview, but I found some hints that it is possible to control it somehow with Labview.
Does anyone has experience with Narda devices?
Thanks in advance,
Eyal.
(4,356 Views)
Eyal,
Can you show us the hints you are referring to? From the documentation I have found, I cant find any information about the Narda EHP-50D.
How are you interfacing with the EHP-50D? What type of application is this?
I cant promise anything, I myself havent used any Narda devices before, but we can do the best we can to assist you.
DChoisnet
(4,329 Views)
I need to integrate the control of my device NARDA  EMR-300 in labview for my thesis  .
Are somewhere any drivers for it?
Thank You
(4,003 Views)
No hits on a quick search, so probably "no".  But if it can be programmed, it can be programmed with LabVIEW.  Find out if it can be programmed.
Bill
CLD
(Mid-Level minion.)
(3,997 Views)
Sure,
It have its own program and it can produce an exel file with the data .
But I can only start the original program and read the exel file with Labview.
I can't manipulate the acquisition mode and command the output.
I wrote a Labview program using VISA driver ,but it doest work most of the time and generate ,in case, only strange results.
I can't do more.
HELP
(3,994 Views)
Wow it was a long time since I wrote this message.. 🙂
Actually I almost not working with Labview anymore.
But I did manage to write my own set of drivers and successfully interfaced with the EFA-300 device. Sorry don't have access to the drivers anymore but I did some searching and found the article which helped me build the drivers:
https://www.researchgate.net/publication/260288653_REMOTE_CONTROL_OF_THE_FIELD_ANALYZER_EFA-300
There is an example at the end of labview code that can be used as basis for the device communication.
I managed to get full functionality almost like the program they supply, just take notice on which values read etc.
Hope this helps,
Eyal.
(3,964 Views)
