navigation while executing
I execute the Application, but i don't know how to navigate? that is for example i create the 7 front pannel, when i click the NEXT button then it will show the second front pannel, like wise in 6th front pannel i click the button MENU then i want to return the first screen. so i need the help about navigation..help me pls....
Message 1 of 25
(5,466 Views)
You can, for example, create a tab control: just config it as an indicator on the block diagram, and wire an integer corresponding to the number of the page you want to display.
To select the page you need, you may also use local variables, or property nodes, according to your convenience.
Regards
Message 2 of 25
(5,453 Views)
You can use "NEXT" Control in each vi as your while termination control except 1st vi. And in your last vi "Menu " as termination control. So as you proceed to last vi and press Home button you will come back to first vi.Smiley Wink
Message Edited by gak on 09-23-2009 04:12 AM
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
Message 3 of 25
(5,447 Views)
Trys this (LV86).
Jean-Marc
Message 4 of 25
(5,435 Views)
hello, thank you so much. i try this main and sub VI's. i saw the front panel of that corresponding block diagram, just what complecated for me, pls can you guidance as a proper way.
Message 5 of 25
(5,399 Views)
Accepted by topic author executing
Main VI
1)         Take the first character of the label (from the control who fired the event) and typecast into a integer
2)         Index "refnum VI []" to obtain the reference of  the subvi you want to open.
3)         Open the subvi (VI1, VI2 or VI3) with the reference
4)         Send to to the subvi the reference of the main VI
5)         Send “VI refnum [ ]” to to the subvi
6)         Run the subvi with "Auto Dispose Ref = F"
At the end of this sequence, the subvi is running and he knows the reference of the main VI and the references of all subvis.
VI1, VI2 and VI3
Boolean “main” or “stop”
The subvi writes, in the main VI, the value True in the boolean control “Visible?”.
The corresponding action in the main VI is:
The front panel of the main VI is now visible.
Boolean “previous” or “next”
1)         Find the position of  “This VI” (in this case: subvi1, 2 or 3) in "vi refnum [ ]"
2)         If we want the next subvi, add 1 to the index and if not, remove 1 to the index.
3)         Index "vi refnum [ ]" to return the reference of the next (or the previous) subvi we want to open.
4)         Write to the subvi the reference of the main VI
5)         Write to the subvi "vi refnum [ ]"
Jean-Marc
Message 6 of 25
(5,378 Views)
Thankyou so much......if any further clarification i post in this sir. thank you...
Message 7 of 25
(5,356 Views)
You should mark J-M's reply as "accepted solution", if it solved your problem
Message 8 of 25
(5,308 Views)
Accepted Solution
Message 9 of 25
(5,287 Views)
executing wrote:
Accepted Solution
This is not the correct procedure. You can find a "Tick" Mark located at the right side of J-M post. Please tick that one and that will show that the thread is solved. You can also do this by, click on the options menu located at the top right corner of J-M post and select "Mark this as solution".
Mathan
Message 10 of 25
(5,283 Views)
