Showing results forĀ
Search instead forĀ
Did you mean:Ā
navigation while executing
Accepted by topic author executing
J-m,
Please dont embedd the images in "large size" unless it is necceasary. It is now very difficult to read it and understand it (atleast for me) :smileywink:
Message 11 of 25
(2,528 Views)
hello,
when i run the application, i move some data to indicators for verification(visit). at that time i need (if any changes) or i edit ( i want tp change ) the data in Indicator, (after i want to store it), what i do? help me please..
Message 12 of 25
(2,517 Views)
hello,
I create one string control, 3D Table and OK button. after two indicators.
when i clik the OK button, the string control (Text) want to compare with Table content. after that it want to display by indicator (Row and column)
please help me..
Message 13 of 25
(2,486 Views)
It will be better if you start a new thread. Can you post your vi?
JM
Message 14 of 25
(2,474 Views)
i attached my front panel.
Message 15 of 25
(2,462 Views)
Message 16 of 25
(2,461 Views)
Your question is not clear. Can you re-phrase your question? Give bit more details about what you are trying to achieve. Your front panel vi is simply showing controls and indicators.
Message 17 of 25
(2,457 Views)
Try pictorically explaining the problem.
Message 18 of 25
(2,449 Views)
ok. please assume The Table having some Data. When i Enter the Text through string control, The data of Position (Row and Column) in table, i need find. suppose no data in that table,  then it want to show "no data" through string indicator.
please help me.
Message 19 of 25
(2,438 Views)
Is this it?
Message 20 of 25
(2,424 Views)
