navigation while executing
Yes, Exactly this is the one i was expecting. Thank you so much....
Message 21 of 25
(1,479 Views)
Unmark and mark vaibhav's post as the solution then.
Message 22 of 25
(1,476 Views)
     when I move the cursor in Front panel, dynamically shows the the Front panel of operation(for easy understand) for Every objects, what ever in the panel...pls help  me...
Message 23 of 25
(1,445 Views)
As muks, mathan and xdaf have already said, mark the solution to your query as 'Accepted solution'
If you wish to start a new discussion topic do so in a new thread.
Your question right now is unrelated to the earlier question.
Also please explain your issue in more detail.
What exactly do you mean to say by
"dynamically shows the the Front panel of operation  (for easy understand) for Every objects, what ever in the panel"  ??
If you are talking about the context help and mean to say that the description changes dynamically as you move the cursor over every object on the front panel, then the way to lock the context help is 'Ctrl+Shift+L'
Please elaborate so we can answer better
Mithilesh Pradhan
Message 24 of 25
(1,423 Views)
Requirement : I would like to display only Labels. at that time the controls want to hide it.
Explanation of Requirement: That is..for example i take one numeric control box.  in that i enter the number like 3 or 4.
Immediately it want to show the 3 or 4 Indicator box with text one, two, three, or four like orderly.
but i like to print that indicator box of label or indicator box of Text alone. I wish to like hide the Indicator box. so only i
wish to display the Text or Label in control box....
Help me anyone...!!
Message 25 of 25
(1,343 Views)
