need LabView 6.1 Runtime engine
I am a test engineer located in one of our repair facilities. I am trying to get some software up and running on one of my test benches but keep getting an error message basically stating that I need to install the LV 6.1 Runtime Engine. Where can I find Laview 6.1 Runtime engine install?
(6,404 Views)
Hi!
Follow the steps from your website to get the LabVIEW driver.
www.ni.com >> Support >> (In Option 3) Drivers and Updates >> Select the right setup for your LabVIEW version and operating system.
Or follow the link
http://digital.ni.com/softlib.nsf/MainPage?ReadForm&node=132010_US
Product Line: LabVIEW
Software: LabVIEW RunTIme Engine
Software Version: 6.1 in your case
Operating system: ???
Hope this is helpful.
(6,392 Views)
On the NI web page select "Support" then "Drivers and Updates" then select "LabVIEW" in Product line dropdown field, "LabVIEW Run-time Engine" in the Software dropdown and 6.1 in the Version dropdown
(6,387 Views)
... or just get it directly from the NI ftp site. 🙂
(6,377 Views)
Thanks for the quick response. Downloaded and installed.
(6,358 Views)
