need help for "From concatenate string insert to mysql table"
Hi mr Mike, the A,B,C just a testing only. Now i have change to as pic below.
I got a question. Can i extract out the highest value in  wind speed column in mysql and show it on my front panel in labview ?
Message 21 of 27
(1,663 Views)
Yes, it's quite easy with the SELECT statement. Google is your friend. Simply search for SQL SELECT MAX. A basic SQL tutorial would be of great benefit to you.
Message 22 of 27
(1,639 Views)
okay noted. Thanks denniss !
Message 23 of 27
(1,624 Views)
Now that things are starting to work for you, it's time to get the database Open and Close out of your While loop.  There's no reason to create/open/close the connection every time through the loop, is there?
Jim
Message 24 of 27
(1,557 Views)
Jim, if i remove ADO Open connection, The DSN=Nyp; link will dissapear, will it lose connection to mysql database ?
Now i added one more to show the Highest wind speed logged. And the connection is as pic below. Can i remove the ADO Open , and Close for both ? Program Pic.JPG
Message 25 of 27
(1,519 Views)
I didn't mean to remove it, just move it outside of your While loop so you're not creating/opening/closing it every time through the loop.  Here's what I meant:
Jim
Message 26 of 27
(1,491 Views)
Ok jim, noted ! thanks for your suggestions 😄
Message 27 of 27
(1,461 Views)
