need help in navigating through boolean pictures
i would like to make a program to navigate through some Boolean controls to its subcontrols. i need to do the same for 4 subcontrols.
pelase see the jpg attachment.
i have a table from which i need to find the sub strings (captions of sub- booleancontrols) from a main control's caption.
here in the attachment, instead of the table, i've shownn columns of table as 1D array of strings.
i'm confused about this way of writing code.
please reply with your valuable suggestions on how can i accomplish navigating through pictures.
thanks in advance
RENN
LV8.5.1
Message Edited by RENN on 04-16-2009 02:34 AM
Kudos always welcome for helpful posts 🙂
(3,291 Views)
Hi RENN,
where do you get your data from? Why do you choose a 1D Array for your data? You can use a cluster with a string control for the "parent" name and an array of cluster for all "childs" and there index in the main array. It would be like a path to the last elements.
Hope it helps.
Mike
(3,250 Views)
Hi mike,  thanks a lot for your reply. i get the data from a table as shown in the attachment.
i need to start from colum 1 of the table. i have to start with PIC 1, 2, 3.
this have to be done for around 6 columns of data.  i've to use this data for the picture selection.
 RENN
(3,226 Views)
Accepted by RENN
Hi RENN,
see the attached example. It shows what you want with listboxes.
Hope it helps.
Mike
(3,196 Views)
oh my god...this code is simply amazing.!!! i've to use boolean picture controls instead of a list box. i#ll try with this..
thanks a lot mike!
(3,190 Views)
hope i can use the value change event for pictures and their caption to search in the string array!
(3,187 Views)
