need help on using more than 28 number of connector in panes
Hai,
There are six subvi's in my utility and each outputting atleast 8 indicators in the panes. In the main program i need to collect all and display. How is this possible?
Any ideas/suggestions?
Mathan
Message 1 of 8
(3,421 Views)
Accepted by Mathan
Message 2 of 8
(3,417 Views)
array
Message 3 of 8
(3,411 Views)
queue
Message 4 of 8
(3,410 Views)
global variable
Message 5 of 8
(3,407 Views)
control references
Message 6 of 8
(3,405 Views)
I ran into that issue with my frist app. I used the worse case connector and diagram looked like a spider.
In the"wrapping it up" section of my Action Engine Nugget I talked about passing value in or out using a cluster. This lets me pass more than one value via the terminal. So you a cluster (type def prefered to make code changes eaier).
Ben
Message 7 of 8
(3,404 Views)
smercurio, you are onto something. I don't want to use global variables. Cluster is a good solution. Queue hmmm i have to start studying it hereafter.
Thanks a lot,
Mathan
[Edit: I hope this is the first thread to get answered in the next minute itself and also it was the solution]
Message Edited by Mathan on 09-16-2009 09:00 AM
Message 8 of 8
(3,401 Views)
