need suggestion on error treating strategy
Hi, becktho,
yes, it's fantastic. It impressed me. I'll try it in my project/
Thank you!
Message 11 of 20
(1,396 Views)
Hi
Criticism is very useful, when constructiv.
Just to answer your comments dynamic:
1. The LV2 global allows me to be safe - if I used a normal global (what I did in an earlier version), I had to use semaphores to control access
2. Well, the numeric ones could also be handled using variants (nobody is perfect - me too ;)), but as this has grown this way I kept it
3. If you have a look at the file-entries in the file, you'll see that they do have a timestampt. Also the log-level and the error-causing module are written to the file. In addition - if the log-file exceeds 10MB, it is backuped (to either be deleted or reviewed at a later time)
Anyway - I'm glad if this tool could help some guys.
Thomas
Using LV8.0
Don't be afraid to rate a good answer... 😉
Message 12 of 20
(1,395 Views)
Hi Thomas,
another great contribution.  I've been thinking along these lines for quite a while now in order to enable "global" error handling in an application.
I always thought that it would be "frowned upon" to de-localise the error handling like this.
Hence my question:  Is this simply a logging feature, or is the error-handling also centralised?  I'm stuck in a timewarp on LV 6.1 so I can't test myself.
I suppose a multi-tiered approach could be used where a centralized threar controls the occurring errors and steers the "global" activities accordingly whereas the low-level error handling is still done locally.  I think there's a lot could be done with this approach.
As soon as I upgrade, I'll try out the software,
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 13 of 20
(1,393 Views)
Hi Shane
Thanks for the flowers :D. Have you been able to look at the code?
To answer your question: The purpose of this library is just to log statements.
Using LV8.0
Message 14 of 20
(1,381 Views)
In this case, sure you can. See if this helps.
Message 15 of 20
(1,382 Views)
Thanks warren for you assistance in conversion to previous LV versions ;).
Using LV8.0
Message 16 of 20
(1,374 Views)
Thomas,
You're welcome.  And Warren, thanks for the conversion.  It's pretty neat, I must say.  I like the distinctive icons too, adds a nice touch.
Haven't had a chance to look through everything but I will definitely get around to it.
Shane.
Message 17 of 20
(1,367 Views)
Shane - any comments are welcome. Maybe I can improve it once more ;).
Using LV8.0
Message 18 of 20
(1,361 Views)
Sorry becktho..
I was working on about 6hrs sleep and 1 neuron.  The last thing I did before shutting-down was double-check for (and overlook) timestamps.
Nice work.
BTW, Here, Ben discusses "Mutex" - the newest  word in my vocabulary. Smiley Happy
When they give imbeciles handicap-parking, I won't have so far to walk!
Message 19 of 20
(1,345 Views)
nice post.
In my projects i use a modified queued msg handler architecture, which helps me trap the errors as they occur. and the structure is very much simple, also it allows me to handle the errors (not just logging) with little modifications in the template.
the template also allows me to locate the area where the error ocuured first.
feedbacks are welcome.
this post has given me some new ideas and soon i will update my template to incorporate new features
you can find me template here
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
Message 20 of 20
(1,337 Views)
