need to convert keithley 2500 dual photodiode meter driver for labview 2012
I installed the driver but found couldn't use it as the driver version is too old.
Anybody can help to convert it so that it could be used in my labview 2012? Thanks a lot.
(4,091 Views)
Accepted by opticprogram
There is separate board for version Conversionhttp://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
(4,032 Views)
accept as solution just to close this wrong posting.
(4,002 Views)
hello, is your problem solved by converting different versions? After converting your file  "ke2500.zip" to different version with one friend's help in this forum, I still found that it cannot succeed to operate VIs you provided. A file named "ke2500.dll" is missed noted by the system when programming. Do you have any solution for solving this problem for me? Thank you very much!
(3,640 Views)
make sure to unzip it, and verify how it was converted, maybe a mass compile will do
(3,614 Views)
Thank you very much for your suggestions!
(3,609 Views)
I have searched through the websites, but cannot find the driver for Keithley 2500. Are you convenient to share the converted LABVIEW driver?
Thank you very much
(3,369 Views)
