need to convert keithley 2500 dual photodiode meter driver for labview 2012
I installed the driver but found couldn't use it as the driver version is too old.
Anybody can help to convert it so that it could be used in my labview 2012? Thanks a lot.
(4,050 Views)
Accepted by topic author opticprogram
There is separate board for version Conversionhttp://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,991 Views)
accept as solution just to close this wrong posting.
(3,961 Views)
hello, is your problem solved by converting different versions? After converting your file  "ke2500.zip" to different version with one friend's help in this forum, I still found that it cannot succeed to operate VIs you provided. A file named "ke2500.dll" is missed noted by the system when programming. Do you have any solution for solving this problem for me? Thank you very much!
(3,599 Views)
make sure to unzip it, and verify how it was converted, maybe a mass compile will do
(3,573 Views)
Thank you very much for your suggestions!
(3,568 Views)
I have searched through the websites, but cannot find the driver for Keithley 2500. Are you convenient to share the converted LABVIEW driver?
Thank you very much
(3,328 Views)
