negative control
I want to input a negative control with lots of decimal values. How can I do that?
(2,892 Views)
If you right-click on a numeric control, use the Format and Precision window to set how many decimals of precision you want. You can always give it a negative value just by either decrementing or typing in the negative sign and your number.
J.R. Allen
(2,892 Views)
