nested iteration(?!)
Hello fellow programmers,
Following is the challenge I'm trying to solve:
I have 2 arrays : WL-Reference & WL-Actuatorscan. Length of WL-Actuatorscan is higher than that of WL-Reference. I'd like to iterate through WL-Reference, and for each element of that array I'd like to find all the values from WL-Actuatorscan that fall within a certain tolerance around that element of WL-Reference and then group them together.
If it was Python, I'd do something like (pseudocode):
for elementRef in WL-Reference:
     for elementActuator in WL-Actuatorscan:
           if elementActuator < elementRef + tolerance OR elementActuator > elementRef - tolerance:
               append elementActuator into a data structure
I'd like to do the same in LV. I've attached the project in a zip file alongside 1 set of example data files. Open the FindOptimisedMicrometerPositionOfLaserLine.vi for troubleshooting. If anyone of you have an idea, could you please fiddle around with the code and see if it works. I still consider myself a novice LV programmer, so I'd appreciate if you could add the code snippet and a little explanation with your suggestions.
Thank you so much in advance 🙂
Message 1 of 11
(4,012 Views)
I think this is what you want?
=== Engineer Ambiguously ===
Message 2 of 11
(4,000 Views)
I would place a bundle node after the conditional output tunnel of the inner loop as the resulting 1D arrays probably can/will have different lengths.
The output of the outer loop will change to an array of cluster of array - in LabVIEW in a 2D array all rows will have the same length!
Message 3 of 11
(3,982 Views)
Thank You!
Not quite what I wanted. However, you gave me enough clue to figure out how to get what I wanted 🙂 See below
Happy coding y'all 🙂
Message 4 of 11
(3,912 Views)
Hi das,
what's the point in inserting into an empty array?
Message 5 of 11
(3,898 Views)
Because it gives me a nice 2D array of reference and detected values:
I don't really know if that's the best way to do it. Perhaps some of my Pythonic practices are spilling over to LV codes. If you have a better idea, please play with the code; its attached. Please note that the code has compounded a fair bit by now.
Message 6 of 11
(3,873 Views)
The output tunnel from the FOR loop already gives you that.  Just remove the Insert Into Array and wire the terminal directly to the FOR loop's tunnel.
Message 7 of 11
(3,861 Views)
FYI, in your pseudocode you have if elementActuator < elementRef + tolerance OR elementActuator > elementRef - tolerance
But your LabVIEW code is set to include the lower limit, so it is equivalent to if elementActuator < elementRef + tolerance OR elementActuator >= elementRef - tolerance
Maybe that's fine. But if you want to change it, right click on the In Range and Coerce node and uncheck Include lower limit.
Message 8 of 11
(3,853 Views)
I agree that your array handling needs some serious work. Let's have a look how you read your file (only the first part shown).
Message 9 of 11
(3,845 Views)
Accepted by SudiptaDas
Here's how you could do the file reading, for example:
Message 10 of 11
(3,828 Views)
