.net assamblay path
Hi
I have private .NET assambly (using WCF). I put all the DLL on the same directory as the project.
When I run the main vi (without loading the project first) it's run OK.
When I open the project first and then open and run the main vi, the application doesn't find the .NET (it seems that when opening the project the application loads different DLL).
When I open the main vi first and then open the project, it run OK. But when I compile the project the exe file is broken.
Gabi
(2,954 Views)
Hi
I solved the problem. The problem was because I didn't use the .config file in the project path.
Gabi
(2,933 Views)
Hi  Gabi!
Thanks for sharing your solution with the NI community!
Kameralina
(2,918 Views)
