waveform chart reference property node "value" won't accept 2-D array
A waveform chart can accept a 2D array as its input, yet I'm having problems if I attempt to use a reference to a waveform chart, with a property node, and wire a 2-D array to the "value" property.  When I do this I get an error that I'm trying to wire something of type 2-D array of doubles to type double.
What should I be doing to ensure I can wire a 2-D array to the "value" property of a waveform chart's reference?
(3,254 Views)
Did you create the reference before you wired a 2-D array to the chart?
I dropped a chart on a new VI. The created a property node. Both the chart and the property node were of type DBL (default type). I then wired a 1D array of DBL to the chart and both the chart and the property node changed to type 1-D array of DBL. Similarly for a 2-D array. Then I created a reference and connected it to a property node. The property node was of type 2-D array of DBL, the same as the chart.
Lynn
(3,252 Views)
I guess I had created the reference and property node before I had wired a 2-D array to the waveform chart indicator.  Once I did that and recreated he reference and property node, it worked.  Thanks.
-Joel
(3,224 Views)
