network shared variable processing
Hello everybody,
  Have someone tried to link the data coming from a Network Shared Variable to an application (running in a tablet or smartphone) made with 'Processing'? I know about Data Dashboard but I'd like to know if there´s somebody working with these two technologies. Thanks in advance for your answers, comments, suggestions, etc.
Impossible is nothing
(3,083 Views)
Accepted by topic author bebin
Hello bebin
Apart from data dashboard there are other technologies that you can use for mobiel applications in LabVIEW
If you are already using a Network Shared Variable, then the easiest and fastest way would be to connect your mobile device and PC to the same network and then just use DataDashboard to read from your published variable.
You can also Build your own thin clients or http webpages and link them to labview, send sms, share a remote front panel between computers
Here is a link where you can read all about it
Cheers and good luck
(3,047 Views)
Hi MarisolM and thank you for your answer. Should I choose your answer as the solution if I have no more comments or questions?
(2,999 Views)
Sure, I am glad it helped
(2,993 Views)
