new networked shared variables in my computer view but not in shared variable engine list
I have a Shared Variables.lvlib on a cRIO target, and want to test some algorithms when I don't have access to the cRIO hardware. Figured I could make a new project, add the same library to the windows target (My Computer). I needed to add a few extra variables, which I did in the original project (i.e. while the library was under the realtime target). Then create a new project and added the lvlib to the project (under My Computer), then wrote a VI to write to these SVs. When I drop a Shared Variable Refnum constant on the block diagram and browse to the Variable Objects, under "Variable Engines" > ni.var.psp > localhost > Shared Variables  the list of variables shows everything except the 6 new variables. When I switch the view to "Current Project" I get the same list WITH THE 6 new variables. However if I select the variables from this list and run the VI I get an error -1950679035 unable to locate the variable in the Shared Variable Engine. Obviously I overlooked something, anyone out there set me straight?
   Thanks for your time   -   lmd2
Lawrence M. David Jr.
Certified LabVIEW Architect
cell: 516.819.9711
http://www.aleconsultants.com
larry@aleconsultants.com
(3,091 Views)
Accepted by lmd2
Hello Lawrence,
It sounds like you may just need to deploy the new variables- refer to this document:
LabVIEW Help: Making Shared Variables Available on a Network
https://www.ni.com/docs/en-US/bundle/labview/page/making-shared-variables-available-on-a-network.htm...
Hope that helps!
Tom L.
(3,088 Views)
Thanks Tom (or Outlaw, if you prefer)
figured it was something simple I was overlooking.
Thanks for the quick solution.
 - lmd2
cell: 516.819.9711
(3,074 Views)
