new window during runtime
Hello.
In my application there is a system that makes measurements.
Then those measurements saved to an array and to a file.
I want to create a button that when pressed new window will open and waveform graph of the measurement will be displayed there.
I understand that i need a subVI but how I make it open in a new window?
(3,507 Views)
Accepted by Tacchi
Go file->VI properties->select "Window appearence" from the categories pull down menu-> and click the customize button and set the check marks as showom in the fig below. This will launch the vi with the front panel visible
Regards
Guru (CLA)
(3,493 Views)
I know that this post was long time ago but I don't want to spam:)
I have the same problem but I don't get this solution;/ How can I make new window visible by a button? When I just connect waveform to subvi and run continously new window appear for a sec and diseappear;/ Can someone show me how to do it?
Regards
Mike
edit:
Ok, I've found how to do it using case and button, but how can I create a button (in sub vi) which will close new window?
(3,234 Views)
To mods - Please join or delete my posts:)
I've found solution! For everyone who has the same problem u can find help here: http://forums.ni.com/t5/LabVIEW/new-window-and-button/m-p/696291/thread-id/319046 2 files - how to open in new window
and here: https://decibel.ni.com/content/docs/DOC-10571: https://decibel.ni.com/content/docs/DOC-10571  <- how to close opened window by button
(3,227 Views)
