newly written tdm/tdms file not found
So I tried it again and I'm still getting the same result where I don't see an actual saved file in the folder.
Message 11 of 21
(2,332 Views)
The folder exists but the tdms file doesn't.  Isn't that what the create option is for though?
Message 12 of 21
(2,324 Views)
That's what create does.  It works for me.  Are you getting another kind of error?
Message 13 of 21
(2,318 Views)
No. there is no error.  I just can't find the file afterwards in my windows folder.
Message 14 of 21
(2,316 Views)
What folder are you trying to save to?  You might have chosen a folder that is protected by Windows.
Message 15 of 21
(2,309 Views)
It's a folder within My Documents.
Message 16 of 21
(2,307 Views)
Just for fun, try putting the file in C:\temp (make sure the folder exists) and see if the file shows up there.
Message 17 of 21
(2,300 Views)
I ended up getting error 7 when I did that.
Message 18 of 21
(2,293 Views)
So I tried just using c:\ and it worked!  I have a cRIO that I am using along side it.  I was reading the getting started with cRIO-logging data to disk article (http://www.ni.com/white-paper/11198/en) and it mentioned that I had to first get it from the cRIO so I tried it and sure enough it was there.  I'm guessing by setting c:\ as the file path the cRIO saves it within itself and then it can be saved to the computer.  I'm sure there has to be a direct path but this works for now.  Thanks for your help by the way.  I'm still not sure why it wasn't letting me save directly to a file on my computer though.  Any ideas?
Message 19 of 21
(2,291 Views)
Accepted by SRamirez
You should have said this was running on a cRIO.  Now it all makes perfect sense.  A cRIO is a computer in itself.  It runs a Real-Time operating system.  Therefore any file paths you define will be on the cRIO.  What you can do is make a network shared folder on your PC and access the folder on the cRIO like you would with another PC on the network.
Message 20 of 21
(2,286 Views)
