‎08-05-2014 12:06 PM
Hi all, I am Currenltly having NI 4551
i need to do a project in wavelet ,so i have installed labview version 13 with advanced signal processing toolkit.
Kindly tell me what are all the device drivers and DAQ card to install .
Solved! Go to Solution.
‎08-06-2014
05:33 AM
- last edited on
‎01-23-2026
08:28 AM
by
Content Cleaner
Hi Kreaks
I understand you are using NI 4551, you can find the drivers for the same at the link below:
http://www.ni.com/download/ni-dsa-1.2/966/en/
If you elaborate the objectives of your project, I can suggest a suitable DAQ card depending on the signal you want to acquire and process.
For more information you can refer to an NI white paper, you will find at the following link: http://www.ni.com/white-paper/3018/en/
If you have any more queries, feel free to ask.
Regards
Rohit Joshi
‎08-06-2014 08:43 PM
first of all thank u for the reply.
I need to acquire the vibration signal and process using Wavelet.
I have currently installed NI DAQmx 9.3.5 and NI Device Drivers.
With the help of traditional DAQ i can able to test the card.The card is working ,
but the options for the card is not coming in the palette.
Kindly tell me what are all the proceedings for the options of the card to come in the palette
‎08-06-2014 08:48 PM
‎08-07-2014
06:15 AM
- last edited on
‎01-23-2026
08:28 AM
by
Content Cleaner
Hi Kreaks
You can find the DAQmx version compatible with the version of LabVIEW you are using at the following link :
https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html. You can find the DAQmx drivers version you need by a simple google search.
Could you please specify which DAQ card you are using to acquire the signal?
Regards
Rohit Joshi
‎08-20-2014 12:57 PM
i am using NI4551 DAQ CARD
