ni 9269 and RST-3-4-40
I want to activate a triac RST-3-4-40 [3~23 VDC, 20mA] by generating voltage by ni 9269. When I generated [1~1.99]V, it was good, but when I increased the voltage [2~10]V, the voltage dropped to [0.94~1]V!
What was the reason? How can fix the problem.
Message 1 of 12
(1,219 Views)
You need to make sure that the current, mA, drawn from you setup can be delivered from the NI module.
Can the ni 9269 supply 20mA ?
Looks like the module can only supply 10mA per channel.
Current drive
±20 mA all channels maximum; ±10 mA per channel typical
Message 2 of 12
(1,196 Views)
Thanks for your response.
I know the ni 9269 supply can only supply -/+10mA.
Message 3 of 12
(1,178 Views)
So you want to drive 20mA from a 10mA source?
Have you tried to use a power supply and see how much current is drawn from the power supply?
Message 4 of 12
(1,165 Views)
Let's me start over.
I have a cDAQ  ni 9269 card generate -/+ 10V, 10mA and I want to control a triac 3V to 24V , 20mA. Can I connect two channels in parallel to increase the current?
Message 5 of 12
(1,077 Views)
Hi alhabeeb,
  • You use a small relais, that only needs <= 8mA @ 10V to switch. Use this relais to enable a the current from an external power supply capable to drive your triac…
  • You can also replace the relais by a transistor/MOSFET…
Message 6 of 12
(1,069 Views)
Thanks. Is it possible to have a diagram of connection?
Message 7 of 12
(1,062 Views)
Hi alhabeeb,
just search for "mosfet driver for relay" to find lots of schematics…
Message 8 of 12
(1,047 Views)
Like this in the attached PDF?
Baqer
Message 9 of 12
(1,023 Views)
Hi Baqer,
When the Crydom SSR works with just <5mA input current then yes…
Message 10 of 12
(1,018 Views)
