ni package managei 安装问题
在安装labview时一直提示  ni-package-manager-deployment-support.msi'安装MSI时发生错误
求解决办法
Message 1 of 14
(2,500 Views)
Message 2 of 14
(2,467 Views)
下载后安装还是出现同样问题
Message 3 of 14
(2,416 Views)
Message 4 of 14
(2,415 Views)
Please enable MSI logging as described here, try to run the offline installer again, and post the logs here.
Message 5 of 14
(2,388 Views)
Message 6 of 14
(2,361 Views)
That is only a higher level log. As this appears to be a MSI error, the MSI log will be the most helpful. Including all of the logs here would be the best:
C:\Users\<username>\AppData\Local\National Instruments\NI Package Manager\Logs
but do at least include the logs in the \WinInstMSI folder.
- Wes
Message 7 of 14
(2,339 Views)
Message 8 of 14
(2,328 Views)
Unfortunately, that folder doesn't include the \WinInstMSI folder. However, it's possible that the MSI logging option wasn't available in the NIPM 17.0 version you are running currently. As such, download the offline NIPM installer from here, using the "Install Offline" button on the bottom right, then scrolling all the way down to version 2022 Q4, which is the latest - and try to install that.
Message 9 of 14
(2,308 Views)
我已经尝试了‘离线安装’,2022q4,这次是我又重试的
Message 10 of 14
(2,292 Views)
