10-13-2022 06:56 AM
在安装labview时一直提示 ni-package-manager-deployment-support.msi'安装MSI时发生错误
求解决办法
10-13-2022 08:48 AM
Download the offline install package.
https://www.ni.com/en-us/support/downloads/software-products/download.package-manager.html#322516
10-20-2022 09:30 PM
10-20-2022 09:32 PM
10-21-2022 11:15 AM - edited 10-21-2022 11:16 AM
Please enable MSI logging as described here, try to run the offline installer again, and post the logs here.
10-24-2022 12:35 AM
Errorlog
10-25-2022 04:30 PM
That is only a higher level log. As this appears to be a MSI error, the MSI log will be the most helpful. Including all of the logs here would be the best:
C:\Users\<username>\AppData\Local\National Instruments\NI Package Manager\Logs
but do at least include the logs in the \WinInstMSI folder.
- Wes
10-25-2022 09:03 PM
NI-log
10-26-2022 03:45 PM
Unfortunately, that folder doesn't include the \WinInstMSI folder. However, it's possible that the MSI logging option wasn't available in the NIPM 17.0 version you are running currently. As such, download the offline NIPM installer from here, using the "Install Offline" button on the bottom right, then scrolling all the way down to version 2022 Q4, which is the latest - and try to install that.
10-27-2022 01:33 AM
我已经尝试了‘离线安装’,2022q4,这次是我又重试的
